ALORS VOILA MON SOUCI JE POSSEDE UNE SAX ANNEE 97 REMASTAURISER.
ALTERNATEUR NEUF MOTEUR CHANGER PAR CELUI D UNE PHASE 2 AVEC TOUT LES CAPTEUR PHASE 1 EN NEUF
MON PROBLEME ET QUEL CE MAIS EN MODE DEGRADER JE POSSEDE TROIS SONDE DE REFROIDISEMENT UNE MARON UNE VERT SUR LE BOITIER D EAU ET UNE BLEU SUR LA CULASSE CALORSTAT NEUF LE TEMOIN RESTE ALLUMER LE VENTILO AS ¨PLEIN REGIME AVANT DEMARAGE .aiguile de temperature as environ 102 DEGRE AVEC CALORSTAST NEUF .
POUR ME RASSURER J AI REPRIS L ANCIEN ET DEFONCER LE MECANISME POUR TESTER CALORSTAT SUPRIMER RESULTAT LE MOTEUR NE CHAUFFE PAS POINT POSITIVE .
LA SONDE LAMBDA ET NEUF CAPTEUR DE CLIQUETIS AUSSI POUR MOI LE PROBLEME VIEN DU CALORST
AT QUI NE SOUVRE SOIT PA AU BON MOMENT OU QUAND PENSAI VOUS
